Logixpro Elevator Exercises:
Downanime00
May 2013
Denver
Hi, I'm kind of new here. I am trying to do the Elevator problems but it's just not making sense to me. I am pretty bad at programming so it's much more harder.
This is the link to the problems.
http://thelearningpit.com/lp/doc/elv/vator.html
If you could please be specific for each of the exercise, I would be very appreciated. If you got the rsl files for each exercise, please just upload it if you find it too trouble some explaining. I am trying to practice how to do these type of thing, it's kind of hard for me to understand. Sorry if my grammar is bad, English is my second language.
Thank you very much.
Thank you very much to the both of you. I will check them out.
For Exercise 2, I am having trouble understanding what they wanted. From my understanding, they want the car to move to the 4th floor and stay there. Is that all they wanted? All of the U3, U4, U5, and so on is very confusing to me. Which one of the subroutine do I use to do this exercise?
Does anyone know how to do this without using subroutine?
Yes, you just string all the files together into one giant file. Why would you want to do that and make it more difficult? You would still need some Step Relays to activate or deactive the different routines. Note that only one subroutine should be active at a time, and when the active one is finished, it either calls the next subroutine, or returns to the main.
The answer is going to shock you: To do Exercise 2, you need the Main Ladder 2, AND these Subroutines:
SBR3 (Called U3 in the Main, for some obscure reason. Initialization - of course you have to do the preliminary variable set-up),
SBR4 - (Called U4 in the Main. Only part of this one, the rungs that check for floor requests on the 4th Floor)
SBR5 (Called U5 in the Main. Next Request, or Wait - You might as well do all of this one - no harder than just doing part for the 4th floor!)
SBR6 (Called U6 in the Main. Close Door and Move - you could do without it and leave the door open, but then you will have to later rewrite your entire routine when you do Exercise 3!)
SBR7 (Called U7 in the Main. Track Car Movement - just the rungs that that check for presence of car on 4th floor)
SBR8 (Called U8 in the Main. Stop and Open Door- you have to stop the thing, but if you did not close the door in SBR 6, then you could sluff off that part, but you will have to do it later in Exercise 3, so why not set up things correctly on the first go-around?)
You see, the truth is that when you start doing programs that are similar to real-world programming problems (for entire systems, not just one little motor), you have to consider the entire problem. It becomes difficult to separate out parts and ONLY do 1 little part, without considering how that part is going to fit into the whole. That is why it is important to develop an overall program organization plan - the divisions or subroutines that you are going to divide it into. Otherwise it becomes overwhelming and very hard to find your way around in the program.
Notice that if you DO eliminate the subroutines for Exercise 2, and only do the part to make a crippled elevator go to the 4th floor, then for your next trick, your instructor is going to require you to do the full Exercise 3, where you must have all the subroutines and all the elevator functions and all 4 floors! So you would be wise only to figure it out once and set it up correctly from the start.
Good morning. I am needing some direction on the elevator sim in Logixpro. I have the ladder written and functional but can't seem to get my stop...
1,609
Hi everyone, I’m new to PLC programming, this is my first post. I finished TheLearningPit’s elevator exercise #4 a week ago and it worked. Wow...
3,079
this is my first post. Can i attach a plc file? I'm creating an elevator simulation in logixpro, and everytime I try to run it, the elevator...
26
16,332
I'm trying the elevator module in LogixPro and after downloading to the PLC when I put it in Run mode it gives the error "Stack Pointer Overflow"...
4,574
having difficulty manipulating I:5 encoder & I:1/15 data for floor control? trying to use counters I:1/15 has a count of 0-124 not accurate to...
3,274
