Long-range RFID(~4m) with distance measurement?
PreLC
Apr 2019
Mars
587
Hello PLCS.NET!
I was wondering if there are options in the market which have distance to tag well as ID of the tag? They need to work in about a 4m range. I don't need a high accuracy for the distance, just something that works.
I'm using AB PLCs by the way, with Ethernet as our standard communication. But other options can be explored.
-PreLC
I think I've seen Signal Strength from readers, but that's not necessarily a good proxy for distance.
If you want a good distance measurement, you can look at something called RTLS, but it's a big jump up in price and complexity.
A search came up with research and development of RFID that gives distance based on the time to reflect the signal off the tag.
Nothing presently available showed up other than this for Arduino
We have installed the Alien brand of rfid readers.
it does have its own communications box. I am not sure if we use SQL to interface into the plc 5/80. my co worker has already left for the day. their handheld rfid readers will do 15 ft.
on their big antenna unit, we had to build a cone to focus in the area we wanted to scan so it didn't pick up the tags in the warehouse.
James
I have a project in which I need to automatically manage some farms. They are asking me to find a way to control some small amount of IOs from one...
1,411
I have an existing system using a Phoenix Contact WLAN 4321 long-range point-to-point Ethernet extender which works pretty well for our purposes...
2,660
Any suggestion on a long range Non Line Of Sight Ethernet bridge or router or even PtP x/r device. Need to connect plant network to other...
1,942
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
215
I have a question. I work in a very large plant and this one (of many hundreds of control cabinets) contains one 5580 (1756-L83E), two 1756-L73...
211
