Looking for a few USB to Serial converters . What are the ones you recommend?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I am looking to purchase a few USB to Serial converters . What are the best , and which ones do you recommend ?
Thanks always for your advice ,
Anything that uses the FTDI chipset.
Had a salesman handing these out for a demo. Work well and free! YMMV on the "free" part.
Just came to recommend the same. It really matters what chipset converter uses, I bought some random Chinese cable and it didn't work (RS232 to USB), while one with FTDI chipset had no issues. I connected Mitsubishi Alpha 2 controller.
I had used the Keyspan USA-19HS exclusively until I ran across one particular radio modem that didn't like it. For that device, I have started using a cheap one I found in a box of old parts. I have used several of those offered by GIT for A/B stuff and they look like this one:
http://www.plccable.com/usb-to-rs232-plc-programming-cable-special-plctalk-net/
I may order a couple of those since just Friday I learned that our new guy doesn't have a plain USB-RS232 converter in his kit.
I would recommend getting more than one type if you are in a field where you never know what sort of gadget you might need to communicate with on any given day.
Brainboxes
I use Brainboxes. They work great both in ExpressCard (not very frequent today) or USB.
Best regards,
Kelkoon
+1 on this one. I have never found something that I couldn't connect to with it.
I also used the Keyspan USA-19HS for a while but ran into intermittent problems when connecting to various Micrologix PLCs.
It may have been a driver issue, but I wanted a backup option so ordered the Omron CS1W-CIF31. It's a bit more expensive but has been bullet-proof so far.
A few months ago, someone posted a picture on their mounting plate for a panel that was labeled up very nicely. It was rather impressive. I do not...
1,727
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
426
181
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
252
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
186
