Looking for pointers on getting RA's Modbus AOI to work.
jstolaruk
Dec 2004
Detroit, SE Michigan
3,915
I'm trying to get a 5069-L306er to talk to a Automation Direct ProSence Controller by using RA's AOI for modbus client but its stuck not getting a message back. Hoping one of the experts here can steer me to what I'm doing wrong.
I've got the Prosense setup with a valid IP address, the AOI reports it has created a socket instance and sets the Sts_Connected output ON. Monitoring the AOI's logic, it creates a new instance (Wrk_Instance) every time I cycle the enable bit.
The AOI indicates it successfully sends a read message (Ref_MsgRead) by setting the message done bit and not the error bit. I placed counters on the enable, done, and error bits to track.
But the Sts_Overload and Sts_Overlap bits cycle ON when just enabling a single read transaction and the destination elements are empty.
I've tested the connection to the ProSence with a number of PC Modbus tools, Modbus_Poll and ModScan64, and they both successfully can send a simple holding register read request, and both agree on the data coming back.
Any thoughts about what I can try next? should I emulating the Prosense on the PC by using ModSim64?
Last resort is to get some h/w but I only need to monitor/modify a single setpoint at very long intervals.
Thanks in advance!
What is the station ID, did you set such in the client parameters?
The target device is indeed natively Modbus/TCP?
I re-wrote the whole thing to accept a variable number of transactions, a single AOI, and a lot less memory, so I’m fairly familiar on this one.
Sweet, I’ll drink another beer since this isn’t one of those cliffhanger-because-the-OP-disappears threads.
Modbus TCP is such a loose standard, so nobody follows it anymore.
AOI follows the standard that requires to have StationID (or UID) =0 unless you have a multiple devices (or stations) within the same IP address. Good example is a bank of valves where each valve will have own StationID starting at 1, while adapter keeps StationID=0.
Another example is I/O rack, with adapter using StationID=0, then modules 1, 2, etc.
From my experience, if you have “Connected” but transactions are failing then try StationID=1 or 255. This usually works.
As it turned out, that was exactly what fixed my dilemma, thank you JeremyM for shaking that loose so quickly. I had followed the recommendation in the RA document that said set it zero.
The last time I recall doing anything with Modbus was in the mid-80s when I had to write a driver to access data out of a Modicon 584. But other than remembering I had done something, the details were long gone.
Thanks for everyone's help!
Greetings. I currently have several systems in operation mainly using Aromat PLCs and Beijer Exter HMIs. The HMIs email to VText.com to send us...
50
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
498
194
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
268
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
201
