Lookout direct alarm dialout
JohnM
Jun 2005
Texas
I have a customner that is wanting to add an alarm call out to his Lookout Direct HMI package. I have done this with Win911 and Scadalarm on Wonderware. Just wondering if anyone has any experience with doing this on a Lookout package and what software they used.
JPM
Well you could always use an autodialer. Some of them are cheaper then both paging packages. Can you still manually configure Win911 for DDE links in an HMI? It's been a long time since I messed with it.
Webhead
It's also been a long time since I messed with Win911. Scadalarm looks at the Wonderware tag database, since it is a wonderware product.
The customer wants to do what Scadalarm does, with voice and text messaging, to both cell phones and pagers. I was hoping someone had used something with Lookout so I could find out about the gotcha's before giving a recommendation on which product to use.
JPM
I don't know if you have tried this yet. You might want to get a hold of an engineer at Automation Direct and see what they can tell you about paging software. They might even have something or be able to point you in the right direction.
SCADAlarm is not limited to working with Wonderware applications. SCADAlarm can work with SuiteLink, DDE, OPC and MX protocols. I would think that LookoutDirect can act as a DDE server, which would allow you to use SCADAlarm.
You may use U.C.ME-OPC alarm notification software product. It is easy to use and offers good functionality. It uses OPC (or DDE) to connect to any OPC server or SCADA/HMI software that supports OPC or DDE server functionality.
Alerts may be sent via: Email, SMS, Phone(Voice), Fax, Multimedia and WAP. It may also be used to analyze your alarms and understand the root cause of the alarms.
You may also send SMS commands from your cell phone to U.C.ME-OPC to change or query tag values(analog/digital).
See www.controlsee.com . A fully functional evaluation version can be downloaded.
Is there a way to do some "Number Functions" similar to the Text Functions ?? what I mean is i have numbers in a Table (from a .xls file) like...
1,228
I have a excel 2007 file with a VB Macro that the user will enter some data on what punch and where to start how many and the "pitch" between...
2,142
Hi, I'm really new in this topic, i need some examples to practice in lookout direct, step by step, Where I can find them, my plc is connected by...
2,135
I am working on a Lookout direct scada communicating to a DL06 PLC through wireless Ethernet.The problem I am facing is, intermittent loss of...
7,179
I am working on setting up several DL-06 PLCs on our printing presses so that we can capture production data (footage, speed, run hours etc.) I...
2,043
