Lookout SCADA registration
ettikudiappan
Apr 2002
Singapore
131
Hi
I am new to Lookout and have an application that needs to be moved from one PC to another. I have used InTouch and RSView, where we get a license disk from which we can move the license. But for Lookout, there seems to be no such disk. How can I transfer registration from one PC to another? Is just the user name and key enough (I have both with me)?
Lookout
Greetings.
In my version of Lookout, (4.0), there is no "dongle", "master disk key", etc. I believe its just the "honor system" (and the CD serial number, of course).
Also, Lookout licensing is purchased by the project tag max count (100 I/O, 500 I/O, etc.), so the CD key determines what tag count is available in the system.
Hope this helps.
tj
Thanks for your replies. There is no hardware key for Lookout. It is just a serial number and a 12 digit keycode. Please see the attached file for the procedure to register. If you need to register a new I/O count, go to Options»System»Change Registration Info
I found that unlike Rockwell softwares, you can not use the serial number of a lower version on a higher version of Lookout.
That is weird, I ran into the same problem today. I have the serial number, but not the keycode.
It came up near the end of the day, so I didn't come up with anything.
(I was also having problems getting setup to run at all on my XP machine)
I was going to call NI if I can't figure it out tomorrow.
I will let you know what I come up with.
I hope you will do likewise.
Hello, Could you give some user/developer feedback regarding the SCADA/HMI system from NI called LOOKOUT - interfacing with HW (drivers)...
1,602
I am working on a Lookout direct scada communicating to a DL06 PLC through wireless Ethernet.The problem I am facing is, intermittent loss of...
7,188
I have a fleet of aging equipment that uses lookout running on XP computers. these systems are stand alone units, most dont connect to the outside...
3,835
Hi. I have a smallish machine on which I want to add internal lighting. My problem is that the available space where I want the lighting is...
5,938
Hi all, I've got a client with NI Lookout for their HMI, and it calls out for alarms through a PCI card modem; they have several remote locations...
1,084
