Loop variation problem in slitter line.
eshan3012
Feb 2016
Jamshedpur
23
I am facing loop variation problem in my slitter line, actually problem is when in uncoiler last 20 to 25 % coil remain either from starting of coil there is no loop variation.
i checked dia calculation of uncoiler & recoiler but dia is accurate from starting to approx 80 % of coil but after that 80 % dia fluctuates & sometime it shows mandral dia which is 508 even when almost 10 to 15% coil remain in uncoiler.
Plz suggest some solution.
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
379
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
286
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
283
Hello All Could we get some expertise on flow control ? -Using a PID loop in Productivity 2000 with an analog output, How can we convert...
19
1,605
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,101
