Lost comms using CCW for PowerFlex
255.255.255.0
Nov 2011
In a never ending fog of "I want", "Why can't we"
Hello all, I have a question for anyone who uses Connected Components Workbench (CCW) software from Rockwell. I am new to this software and am using it for the first time on my current project to install a PF753 drive for a machine upgrade. I am losing comms with the drive. I am using a USB adapter connected to a 1203-SSS serial converter from my laptop to the drive (same set-up I use for PF70 drives). Driver is configured as follows: Device = 1770-KF2/1785-KE/SCAN port, 9600 Baud Rate (matches the baud rate uploaded from the 1203-SSS), Parity = NONE, Error Checking = BCC, Protocol = Full Duplex. Goes online for anywhere from 30 seconds to 2-3 minutes. No real pattern to it. Usually stays online just long enough to ALMOST complete a download....then kicks me offo_O. Have to go re-configure the driver every time it kicks me off before I can go back online. Even tried deleting the Harmony file and doing a complete new configuration a few times...same results. Finally got so irritated that I just entered all of the parameters on the keypad of the drive and used the CCW on my laptop as a reference. I need to be able to stay online so that as I can tweak and tune the drive. Any thoughts?
My ip address is 10.2.2.200, the compact logix L 33E is 10.2.2.129. I go online and within 30 seconds I get booted and I'm pretty sure this...
1,706
I no longer have an option to select df1 path and was wondering if anyone has ran across this. I can configure in RSLinx Classic and see the PLC...
2,048
Hi guys, I've come across a very odd problem that I can't figure out with testing communications failures and my 1756-L72 ControlLogix PLC with a...
5,608
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
83
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,127
