We have one PanelView that is generating about 67% of all packets on it's subnet. Approximately 49 ARP requests per second. I believe it may be a PanelView Plus 1000 (I was told it runs Windows CD).
We have a second PanelView which I have not seen personally (So I don't have the model) that's also scanning constantly but at a much much lower rate. I suspect they are very close as they both have a FactoryTalk Viewpoint screen that shows when you try to access them over the network from a web browser (followed by a message that FTV ME is not running)
I was also told that they can manage PLCs from it as well, so it sounds like it can run RSLINX.
I suspect it's constantly scanning over and over again for what it can see. The device is in an area where they would be unlikely to suddenly have a need to manage some PLCs from it.
Wireshark captures show it looks like it's just going through all the IP addresses in the scope (255.255.254.0) which is a little over 500; over and over again.
Can that constant ARPing be disabled or dialed down?
