Low power sensors for LPG
aism
Jun 2019
Brussels
Hello there,
I need to precisely measure total mass in an LPG tank.
The types of sensors I'm going to use are:
- level transmitter (without moving parts)
- pressure transmitter (gauge pressure)
- multi-point temperature sensor
- density sensor (optional)
These will be controlled by an IOT device.
I'm going to use battery power for this setup, so I need low power sensors for the task.
I found some low power pressure transmitters:
https://web-material3.yokogawa.com/FGP-310__1st_edition_.us.pdf
However, I failed to find low power level transmitters. Could you please give me some hints?
Also, if you could suggest density and temperature sensors for this requirement, I'd like to hear.
Does anybody know if there's a way that I can have Logix Designer apply the green highlight to ALL elements that evaluate true (not just XIO/XIC...
1,806
Inductive load: Vacuum Pump motor 115VAC 0.9Watts Resistive load: Heater 115VAC 0.75 Watts What is the best way to control these from...
2,021
Anyone have any suggestions? Looking at max of 3W about 10 I/O with Ethernet and if possible a safety one at that! Cheers for any suggestions
2,189
Good Morning , We have been running a machine , PLC and PowerFlex 525 for over a year. For some unknown reason , I have a Yellow Triangle on...
4,471
anyone have any experience with very low power plc's? It seems hard to find a plc or programmable rtu that has minimal IO that pulls very little...
6,425
