Low voltage in Germany
No it's not..
Germany (like the UK now) is 400/230v, the same as the rest of Europe
I felt like having a good argument here (haven't had one today, yet :D), then I remembered noticing the voltage on my power monitor at home last week and it was, indeed, 227 V.
When the voltages in Europe were initially standardised (a long time ago now) the tolerances were set wide enough (10%?) that in fact initially nobody needed to change.
Does this mean that the voltages in the various countries are slowly drifting towards actually being 230V?
What voltage do you have in the UK now Paul (measured)?
Roy
Measured voltage in the UK is still around the 240v mark.
Although our wiring regulations (16th Edition BS 7671) quote 40/230v.
I still do my calculations for cable sizing etc using 415/240v, not 400/230v.
Paul
P.S It's never an argument, just a discussion, sometimes heated!
I seem to remember reading that the tolerance is coming down to 5% which gives 400 +/- 20.
Old German motors are 380V all new European motors should be 400V. I still work on 415v for wire sizing too.
I have a 30 year old Symax PLC. Lately two of the outputs are putting out approx. 8vac continuously without the output being energized. All the...
2,273
I have a analog card 1715-IF16 with six 4-20ma instruments on it. The card in a single-ended method. The instrument has been service for a while...
2,530
Can a low voltage electrical panel be designed to be opened without powering it off first without violating any electrical codes? Panel will...
1,957
Good afternoon, I have an Allen Bradley PLC 1768-L43 with one 1769-IQ32 input card and two 1769-OB16 cards (all three on the right side of the...
19
7,968
Hi All, I have a project at the moment with a Festo PLC to be sent to the states. It must adhere to UL standards which I am not familiar with...
2,392
