M221 and SoMachine Basic
Blevine
Mar 2018
Leicester
Hi guys,
I'm using M221 PLC from Schneider with Somachine Basic, and I have two problems as of the moment.
1. It seems like my software is not getting the actual value from my pressure sensor. There are discrepancies, like 50, sometimes 80. Is there a way for me to calibrate my sensor or do something using the PLC function blocks?
2. I can't read the modbus values even when using modbus reader like doctor, modbus simulator, etc. Kindly help?
I'm a beginner so, please extend some patience in answering my questions. Thanks a lot! Have a great day!
Thank you Garry! I will look into these.
Do you have any idea about the modbus register/address for the M221 PLCs? I would need some registers and read it using some modbus simulator/reader. Any idea will be of help!
Blevine
http://www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/240000/FA240029/en_US/Modbus%20TCP%20Slave%20Device.pdf
I would start with the above document on Modbus Addressing.
I would use AdvancedHMI for the testing. It is capable of testing your communications and offers a good HMI interface. (This is a free package that runs on visual studio.)
https://sourceforge.net/projects/advancedhmi/
This link will help get you started with AdvancedHMI:
http://accautomation.ca/create-a-plc-with-hmi-training-and-learning-environment-free/
Regards,
Hi all, I've been trying to develop modbus rtu program between uv balasts and plc ı'have 6 slave balast.I am reading fault run voltages etc...
1,199
Hi Guys, I'm using M221(TM221CE24R) PLC and SoMachine Basic from Schneider and having a bit of problem. 1. I can't able to read the data from...
1,748
Hello! I am new at PLC programming. I am using TM221CE16R PLC with TM3AI8 analog input module and SoMachine Basic v1.6. I am trying to scale...
7,073
this is my first time using this software,trying to scaling PT100 (scale unit -2000~8500) using simulator but the result so funny,can somebody...
2,450
Hi All, I am a newbie to Modbus tcp communication, and need some directions in this regard. I have TMCE221CE16R with SoMachine Basic as my...
5,459
