M221(TM221CE24R) and SoMachine Basic
akd.jrdb
Feb 2014
Philippines
17
Hi Guys,
I'm using M221(TM221CE24R) PLC and SoMachine Basic from Schneider and having a bit of problem.
1. I can't able to read the data from the PLC using modscanner.
2. I don't know what configuration to do to communicate it with our HMI since we can't read any data from PLC using modscanner.
I am new to this software, please enlighten me :)
Thanks a lot.
Have a great day!
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
193
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
87
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
118
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
109
Hello all, I need to build a system that will operate various AC contactors and 'lock' them out for a predertimed time when a set current value...
324
