TMC2CONV01 x TMC2SL1 for Schneider Electric M221?
Paulo Balbino
Feb 2023
Abu Dhabi
I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01 and TMC2SL1 cartridges? I am looking just for an extension port for the M221, so I can work with generic devices reading/writing (Read var/Write Var) from different sensors.
I tried adding them to the Schneider Electric Machine Expert Basic, they seems similar.
Thanks,
Paulo
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
43
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
134
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
65
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
107
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
189
