M340 Peripheral Remote I/O Adapter
Matt1234
Apr 2013
Australia
Hi All,
I have an M340 PLC in a switchroom and the need for one or two other M340 racks in other locations. I'd like to use M340 I/O for parts standardisation and my understanding is that the BMX PRA 0100 would be suitable.
I've added a NOE 0100 card to the main rack and a new communication network. I can then add a PRA device to the IO scanner in the network for the NOE and launch the PRA tool which launches another Unity Pro program with a PRA rack preloaded.
My question is that given that the NOC 0401 card looks like it will eventually supersede the NOE 0100, is there an equivalent set up procedure for it? I have scoured the manuals but have not found anything.
Regards,
Neither have I - have an M540 to do and it uses the NOC 0401 need GeoffC here for this one I think. Help Geoff.
Have yet to use a NOC module in a project only done a little training
To set up a NOC you use the dtm tool within Unity. This will let you setup io scanning for the module. Not sure about setting it up to use with a PRA
I would suggest you give Schneider tech support a call
I will have a look at the tool Geoff and see how I go - trouble with support just getting to the second level is hard enough sometimes and trying to get to someone who knows something is almost impossible. Had some issues trying to read from a breaker some time ago with Modbus RTU - eventually got sorted - the breaker was on a generator from the US and the factory in Mexico had not updated the firmware! Took 3 days to find out what was going on.
Let me know how you go with the dtm tool. You open it from within unity.
Probably not the best time of year to need tech support
Any time I use tech support almost straight through to level 2 and when required elevated to level 3 and an answer from France within 24 hours
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
265
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
154
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
324
I'm using M340 (Schneider Electric) as modbus master. It works fine but if there is a disconnection with the slave, it stops working even after...
433
Hello, I am trying to send sms messages using SR2MOD03 with an M340 and can't find anything related to it on the internet, can you please help...
209
