M340 set change ip
In UnityPro add a Communication->Networks object:
Then link it to the processor Ethernet port:
Suggest downloading the first time with USB, then once the IP address is set as you wish, then connect with Ethernet.
Thank u for the response. I was able to change the ip only while not connected to the processor, then I had to do a build project followed by downloading the code with the new IP. Is this correct? is there a way to change the IP while being online with the processor?
Thanks,
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
268
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
157
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
325
I'm using M340 (Schneider Electric) as modbus master. It works fine but if there is a disconnection with the slave, it stops working even after...
442
Hello, I am trying to send sms messages using SR2MOD03 with an M340 and can't find anything related to it on the internet, can you please help...
210
