mA Output Freezes at 16mA
jaguirre
Oct 2018
Manila
Output stops when it reaches 16mA (75%).
0% -> 0mm -> 4mA
25% -> 2400mm -> 8mA
50% -> 4800mm -> 12mA
75% -> 7200mm -> 16mA
100% -> 7200mm -> 16mA
Happens at PLC side.
Do you experience or encounter the same problem?
Output from Yokogawa DCS were simulated, works properly from 0% to 100%.
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
69
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
319
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
