Magnetek VFD problem
Neilgrimsley
Dec 2010
South Carolina
26
Let me start off saying how much i am going to appreaciate and enjoy your posts on this topic. I can use the ideas ...
i have two identical (?)presses with 100HP motors. They are being controlled with MagneTek GPD 515C-B128 drives .... One is running fine but the other is faulting out with a "DC BUS OVERVOLTAGE" fault anytime the speed decreases on the drive. Ramping up is not an issue, only when we slow it down or stop it. The DC BUS does spike in the range of 700-800 volts when it faults, so it is real ....
Any suggestions on what could be causing this? I have checked the parameters between the two VFD's but feel free to point me in that direction, if you feel I may have overlooked something. Any ideas will be greatly appreaciated.
+1 for what Keithkyll said. Also check the incoming AC line voltage. It may be near or above the recommended high limit.
I'd say, given the age of those drives, the bus capacitors are low in value, or may be open.
As large as those drives are, the DB resistors are external, so checking them will be easy.
If they are good, I'd check the bus next. Are these in a warm environment? I once got called to
fix an older AB VFD that was in an airconditioned room after the A/C failed. Every bus capacitor was open! New capacitors had it back up with no other trouble.
if you turning a flywheel so , check the load by measuring the current consumed through a specific speed , compare this value with the other press at the same speed , then compare the 2 current readings , then you will realize if you got more load on that flywheal , then the solution would be to check the grease system for it , or you might need to help to stop it with a mechanical pads for the brake.
Recently I have requested a quote from Magnetek for their Impulse Drives but can't raise a response from them. I've requested a quote FOUR TIMES...
1,084
Hello I am looking for manuals on Magnetek MCD 800 and MCD 804 servo drive and power supply. Not too much on the web, aside from joints like Ebay...
1,751
First of all, sorry not really a PLC question, but am going to ask anyway, There are a lot of exp. users here, incase someone has come across...
1,941
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
111
So i need to communicate my VFD (LS Electric iS7) with XGL PMEB module i successfully set the gsd file now i cant figure out how the data works...
66
