Major WinCC Flex licence problem
orense
Apr 2006
Norway
196
Hello,
I have a problem with my 2007 WinCC Flexible licence.
On my pc I have Simatic 5.4 Step7, Protool v6.0 SP 2 and Flexible.
Earlier this week I got some problems with running Protool, but I did not bother because I rarely use it anymore.
Today I was working with flexible and suddenly I got bluescreen of death and the pc rebooted.
Problem is that after it booted there was a message that there was no licence anymore.
I went into Licence Manager and it told med that the licence was corrupted and defected.
I borrowed another from my colleague. I am heading to Cape Town on Tuesday so flexible/simatic working is quite crucial.
But when I tried to delete the defected one, the manager told me that it could not be used because it was in use at the present time. I tried to transfer it also, but got the same message.
I do not take the chance of trying to overwrite it whatever, because I do not want to loose any licence which is okay.
Has anybody been in this situation before?
I do not know what to do. If nothing here I probably has to contact Siemens....
Thank you for any suggestions...
Andreas
I had an experience where I got those messages, "No valid License Key was found", "License Key in use", and "License key is corrupt." I tried the procedure in FAQ 15293567 from the Siemens web site, but it did not help me. Maybe it will help you. I used a procedure with the Siemens hotline where I got a number from the Automation License Manager and they told me an activation number to type in. It was actually a pretty quick process to get me running again. I hope this helps.
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,057
Hi Guys Today we went through the worst situation that PLC went to major fault Mode due to Trap by one of the Timer with -ve Value Moved into...
1,025
Hi, We are having issues with an intermittent Major error code 21h. The plc can be running for varying amounts of time before faulting anything...
1,891
1756-um004_-en-p From the manual above, 1756-EN2TP supports PPP communication, and the 1756-EN2TR has an embedded switch. Is the EN2TR embedded...
2,821
Hello everyone, has anyone had this problem before PLC 5000 Model 1756-L81E Major Fault Type 4 Code 20 (T04:C20)
4,294
