make chart with fixed parameters
grazianogogo
Supporting Member
Mar 2012
China
Hello everybody,
Is it possible to insert in rslogix5000 a chart with fixed parameters that can be chosen regarding a tag value?
I make an example :
I have a gas and regarding the reading pressure I can understand the temperature by follow the enthalpy chart.
There isn't any formula can match the pressure and temperature ...
so, I need to copy the temperature/pressure chart inside the plc program and let it choose the most close value.
there are more than 80 parameters and to compare all it will be complicated and long file ..
DOES ANY ONE HAVE EASY SOLUTION ?
THANK YOU VERY MUCH FOR ALL SUGGESTIONS.
Graziano
What size is the chart? How many values are we talking?
You could do it easily with compare instructions such as GEQ, LES, etc. and Move Instructions.
I would look at the FSC instruction. (File Search and Compare)
Build 2 Arrays Pressure/Temp. The FSC instruction can lookup the Pressure and it will return the position in the array. Then use that position to look up your Temp in the Second Array. If you look at the example programs located in RS5000 Check out the BarCode Lookup Example. This will be simalar to what you need and may help you find a solution.
Hey All, I am attempting to create a bar graph(histograph) in FTView Studio. I would like to graph water consumption for each day of the week (7...
1,394
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
674
Anyone used the ActiveX Chart Control for their HMI Programs before? Short Demo Here : https://www.youtube.com/watch?v=jrS41-PhSGY Some Rockwell...
1,297
Hi guys! I'm new in SCADA and VBA programming. I'm trying to add 2 date pickers for start and end date to show trend history between them. I found...
2,184
I'm trying to get beyond "do-done" programming and utilize higher functions to make my routines smaller and easier to write. I've just started...
1,563
