making a new filename.rsv
George Graziano
Jul 2004
NY
447
I made changes on a display screen. I tested it on the server that has RSView32 Works on it. My question now is, I can't seem to find how to save a new filename.rsv. Which I can then copy to the clients.
George
If it is just one screen can't you save the new screen and replace the old current one in the project?
Hope this helps
Bob,
It was 4 screens. That is the problem, how do I create a new project(filename.rsv)? I don't see any menu item. Or, is that a separate program that does that?
George
Any reason not to replace just the four screens instead of creating new project? This assume that you didn't add new tags.
That is what I thought I would do. But, on the clients, it doesn't appear to "Hold" the graphic files. When I start the clients up, I just start a single filename.rsv file up. I did a search for filename.gfx and it didn't find any.
George
Is the customer computer running a stand alone .rsv or is the application on a server and the is customer using RSView32 RAD [Remote Active Display]to use the application?
Under RSVIEW 32 tools is a utility called "TRANSPORT". This gives you the option of saving a project using a different filename. Check under Start, All Programs, Rockwell Software, Rsview 32 Tools or something similar that gets you to the Rockwell software installed on your computer. Hope this helps
The client can't run on its own. It takes data from the server. Actually 2 servers and 3 clients. The 2nd server only kicks in if the 1st one stops responding. Only server 1 has the editor software. Does that answer your question?
George
Make your changes and save them on the server.
It has been a while since I worked with RSView32 but I think you then have to either reboot the client or the server for the clients to get the new screens.
Hope this helps
Great, I will try this in the morning. We are powering everything down to move the server back.
George
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,015
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,526
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,885
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
879
I was taught to go to Combined > Make Change > go to Offline > will prompt to save > Save > Exit out of program > will prompt to save again >...
681
