Making a variable speed exhaust fan.
Kreutzer72
Apr 2003
San Diego, CA
I know this has nothing to do with PLCs. I just was wondering if anyone could steer me in the right direction. I got a soldering exhaust fan out of the dumpster. Well 3 to be exact. They all work. Score! Yet I wanted to make it so I could turn them up or down. How do I figure out what type of (pot) I need? The fan is a Fulltech model # uf-12a12.
The specs are:
Fan rated voltage-120v/230v
Frequency-50hz/60hz
Input power-17W/15W
Rated Current-.21,.19,.10,.09
Locked Current-.22,.20,.11,.10
Speed-2700,3100rmp
Just was wondering how I can figure out with an equation what type of pot to use to adjust it.
Thank you for your time and help.
Joshua
You may want to use maximum current of 0.22A for the POT minimum rating.
As for the resistor ohms are concerned, use the value which closely match your desired speed-change.
:oops: (A resistor of this rating may cost you as much as the price of a small VFD)
A cheap 500 Watt light dimmer should do the job for you. You could also use a ceiling fan speed controller. I believe these are essentially a light dimmer which does not go to zero output.
This is a good bit out of my specialty but, wouldn't a variac be a better choice here?
And, being single phase, am I correct that only a little speed reduction is possible before the motors just go limp?
From the locked rotor currents, they seem to be a shaded pole type motors there. From the speeds, you don't have a lot of poles.
You might be able to achieve some basic speed control, but not a lot.
Frankly, you'd probably get better results with oh, say, 12 or 24vdc muffin fans and a small variable dc supply.
I'm probably in the realm of 'Nope not Possible" here but here's my issue. First things first. FactoryTalk View ME V9.0. I'm new to the company...
5,333
Is there a way to make a variable non-volatile in a BC9000 when a digital input is cycled on / off? Change a variable to a constant? make the...
1,635
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,016
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,527
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,886
