making an output toggle at different speeds!!
ryand
Aug 2005
NW
Hey Guys,
How do you make an output toggle at different speeds. I want a light to blink slowly and then speed when a different condition exists? Thanks for the help!!!
What PLC?
In SLC, they have status bits from the clock you can use to do this. In the Logix platform, you can use a GSV to get the clock value to do the same thing.
Where are you in the NW?
More of what dmroeder has stated....
Just about every PLC has 'special bits' these bits are preconfigured in the CPU, automation direct (Koyo) has SP bits, SP4 and SP5 for example are bits that turn on and off at SP4 true and false every second, SP5 100Millisecs
Allen Bradley has S2:4/4 and S2:4/5, Mitsubishi has SM412 and SM410, S7 200's SM0.5 etc...
In AB double click the Processor Status file in the program tree (left side of your screen) once the window pops open change the view to binary (lower right side) scroll down to S4 these are you running time values that you can choose
I don't think the ML1000 has the free running clock bits. You will have to build your own flasher bits in ladder.
I threw together one way of doing it, there are many others.
Hi Ken,
I use it all the time....
But along the same line as you "there are many others" here is another way.
MicroLogix 1000 Analog!!
If you want a light blink rate that is proportional to an analog value, take a look at this version for a MicroLogix 1000 Analog.
EDIT: This program may cause overflow error, or give wrong results. Let me come up with another way to do the math. I will be back later.
After looking up actual values of the MicroLogixc 1000 Analog Inputs, I see that they are 6241 to 31207, so I revised it yet again for those numbers.
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,024
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,552
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,903
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
889
I was taught to go to Combined > Make Change > go to Offline > will prompt to save > Save > Exit out of program > will prompt to save again >...
684
