Making multiple s7 projects
interlock
May 2011
Middle East
29
I have about 10 FCs in a s7 project.
I want to make separate s7 projects for each of those 10 FCs.
What would be the easiest way?
Regards
These are not real machine codes ........... just for experimental purpose.
The project containing 10 FCs are independently operating without any relation to each other (neither they are a part of real machine coding as I said before).Each FC contains different ways of programming (like indirect addressing / LOOP command / Timer projects which were integrated with WinCC Flex/ etc).
So, in short, I wanna have them as a separate "identity" in terms of separate / independent s7 projects.
Regards
As JRW - use SaveAs and then delete the FC's you dont want from each project.
You can insert multiple programs into a project/library to keep the FC's separate:
On the left hand side of the AB program I have on my screen, there is Ladder 2-7. Hows are these individual ladder sections created in the...
4,893
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,040
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,574
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,918
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
896
