Tark Member T Join Date Apr 2004 Posts 503 Jan 1, 2006 #16 That is correct. EZ Touch has a BCD_INT_16 for a datatype.
stimpsonjcat Member S Join Date Jan 2006 Location GA Posts 2 Jan 3, 2006 #17 If you want to target a double BCD number from Lookout Direct, you will need to use the B extension. The available extensions are: :B for 16 bit BCD B for 32 bit BCD (i.e. UDC accumulator) :R for real (IEEE format) no modifier is decimal data You might also have simply used an INC or INCB instruction if your accumulated value need not exceed 9999 or 65535 respectively.
stimpsonjcat Member S Join Date Jan 2006 Location GA Posts 2 Jan 3, 2006 #18 LOL smileys are : D B without the spaces That's pretty funny!
