mapping output to modbus address in Somachine (M258)
aqueousdan
Jan 2016
uk
32
Does anyone have any knowledge regarding mapping my output (%QX0.0) to a MODBUS address in Somachine 4.1? I want to be able to read the status of this output using SCADA software eventually (Ignition)
I am pretty much unsure where to find information on this from Schneider. (No helpful user forums like there are for Siemens!)
Thanks,
Dan B
Thanks,
Dan B
Not SoMachine but he same principal....
http://www.plctalk.net/qanda/showthread.php?t=106777
Thanks for your help guys. I understand that I cannot directly map my input or output to a modbus address and so have followed the example to change the status of memory bit %MX0.0 instead.
Now I get the following error. I cant seem to work out how to map this to the modbus.
Hello, I am still learning crimson 3.1 programming and I need help on mapping the flag datatag to digital output expansion module. I am using a...
1,593
Hi Guys How do you map the inputs for your machine when using FB's? btw I'm using Twincat 3/Codesys. Right now I map all the input/output to...
1,945
Let's say my PLC has a 32 terminal output card called Local:3.O.Data. Which of the two options below is a better way to map the output? Or is...
2,006
My HMI (PanelView C400 TFT Color ) won't allow me to use an output address in a Tag. So I have to map the outputs to b3 bits. Is a Move the...
2,133
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
417
