MATC-Pause cam profile
noorloai
Jun 2015
ontario
25
Hi all,
I have an issue with programming MATC instruction in studio5000 V28.
What I really need is a way to stop the cam profile when Axis stops and when its resume, the Axis should move from where its stop in the cam profile.
Right now when I pause the instruction, everything pause, but when rerun it again the cam profile run from 0.
is there any way to do that? any suggestion/documents would be really helpful.
I appreciate your response in advance.
Yes you are right, but in my case I am using the MATC with virtual Axis to change the speed of real drive.
the position of virtual axis represent the speed to my real drive. therefore, resuming the camming will reload the cam profile back from zero. I am looking for way to pause the cam profile so I can get right speed to my drive?
I'm using a MATC (Motion Axis Time Cam) for a servo application. If I change the Time Scaling value of the MATC instruction while the cam is...
1,491
Hello All, I have been working on a pick and place machine using the ControlLogix motion. Two hydraulic servo axis for the pick and place...
6,492
Hi, I'm programming in RSLogix 500, and I'm wondering how I would program a Jog command that does not increase the encoder count. Basically we'd...
306
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
797
Sometimes in a specific Project I need to disable all the output of the system, Then I can Resume it again by Pushing The Same Button ( Pause ) or...
2,197
