mater k120s
yako66
Nov 2012
matanzas
Hi everybody:
Is it possible to connect LS master k120s to ethernet network?
If it is possible,please I need help.
Best regards
Jesus
http://plcegitim.com/plc-kursu/wp-content/uploads/2016/12/MK120S_Users_Manual.pdf
Your PLC K120S will not communicate to a Ethernet network directly. It will however communicate serially with a Modbus RTU protocol. You can then use a protocol converter to communicate over Ethernet. Similar to the following:
http://www.redlion.net/products/industrial-automation/controllers-and-data-acquisition/data-station-plus
http://www.plctalk.net/qanda/showthread.php?t=64936
Hope this helps you out.
Regards,
Good morning Sr:
Thank you very much.I appretiate your help.
I am trying to connect an HMI weintek (eMT3070A) to a PLC (master k120s)which located at a distance impossible to be wired.Your INfo have been very usefull.
I will try to do my best, but as i have no direct experience working over ehternet in PLC and HMI communication,i still have no idea how addressing HMI to stablish comunication with the remote PLC.
Sorry for my English.
Best Regards
Jesus.
Hi, I am new to this forum. I am trying to get into the program offline of one PLC Fanuc GE 90-30. To see the program I downloaded the software...
541
Can anyone point to documentation indicating which parameters can be changed while the Yakawa P1000 VFD is controlling a motor? I am trying to...
1,002
I am using a MVI56-MCM Modbus Mater/Slave Communication Module for a project my company is doing. I am writing all of the software(RSLogix -...
1,876
One of my team members is working on a rather large RSView32 project. He has about 50 tags on a template page that will be updated via a parameter...
1,518
I have a client that has a TI310 PLC Programmed using GE Fanuc Logicmater 1F and the memory was erased, I'm trying to reprogram the PLC using...
1,595
