Math Help - creating a variable scaled analog input
Jeff164
Mar 2017
NJ
Hello - you folks were kind in helping me the other day so I'm back for more...
My program is finished however the end customer hasn't provided a positive confirmation of the range of the pressure transmitter they are using as yet.
PLC: AD DL-06 HMI: C-More EA9
I'm wanting to provide a numeric entry box behind a password protected setup menu where their installation project engineer can input / adjust if need be the full range value for the transmitter. The ANSCL iBox tool will only allow constants (Knnnn) for inputs here (I thought this would be easy if I could have just entered a V-memory address for the High Engineering value).
Anyway - I'm trying to develop a formula that will allow me to bring in the assigned value and write to V-memory, run the math and then output to the PLC code for set points and display.
I got the code functional for moving the data into the program and setting up the structure, but the equation is giving me challenges. Its been too many years since I sat in algebra & trig classes with this sort of thing and I haven't been using those skills of late.
Here's a screenshot of what I've done. Its functional but the math is broken. o_O
thanks again !
drbitboy is spot on one of those threads is quite recent so should give you some ideas on how to roll your own.
This application has a motor with encoder feedback that drives a linear actuator that moves in/out, and is at roughly 45 degs from horiz. As the...
19
1,365
Hey guys, I have MLX LOGIX1400 running fine except that it faults sometimes on math over flow. I examined the program and spotted a...
2,325
Hey guys, I'm programming this stepper motor to go back and forth at two set angles. After programming, I realized that my program only works when...
2,286
Hello all, I am trying to synchronize the speed of two motors so that once an operator sets them both where they want they can push a button that...
2,713
I am taking a Simple SP which is in BCD and adding to that, When doing so I have noticed if the value is < 8 it works out fine, but if > 8 it...
2,492
