Matrix Math with CompactLogix PLC
tspisak
Aug 2005
Corning, NY
72
Has anyone done matrix math with a A-B PLC?
Not sure if I should be using loops and indirect addresses or go with hard coded program with every separate equation programmed. It would be great to find a clever/elegant sample code and then expand for my application.
I did once long hand using a SLC500 many years ago. Now, with the FBs, AOIs or ST (structed text), it would be a lot easier. Would have to be mindful of math overflows.
I have a robot measuring a bunch of points around a outside diameter of a part. Calculation is to calculate out of round measurement. Coordinate measuring machine type stuff - no control, just data.
Mine was similar but measuring the flatness of a transmission part with multiple LVDTs on a face. Establish a plane using (3) LVDts, then calculate the other LVDts measurements, compare, and report the difference.
Hi All I have a project where I need to scan some barcodes with this Matrix 220 sensor via profinet. CPU 1517F-3, using TIA v17 I was looking...
663
Hello everyone, I need to replace a datalogic matrix 300n that doesn’t work. I used DL.CODE to give ip address and everything works: ping and go...
373
hello everyone i have a question about how to extract date from the datamatrix and read it in the tia portal v16 :site:
1,441
Not sure how many have seen this by now, but I like it https://www.youtube.com/watch?v=FaR9rVXUkJo Not sure how often it will be used
4,258
Hi, I'm looking for the older style compatibility matrix Rockwell used to have which lists which CPU's are compatible with which ENET/CNET card...
1,686
