Matsushita FP1 C40
ADoozer
May 2013
Albury,NSW
40
Hi all.
I'm looking for a pinout for a cable to connect to a Matsushita FP1 C40 PLC.
I believe it will be 9 pin d-sub to 9 pin round connector (similar to a micrologix plug).
Any info greatly appreciated.
Regards
Dave:beer:
If it's a round plug then it might be a 5-pin mini DIN as is used on some of the other FP models.
I don't have experience with the FP1 but the pictures I found on Google appear to show a Dsub connection on the PLC.
Everything you need to know is in that diagram... pin numbers and names on each side of the cable. I assume the "conversion circuit" has to do with converting RS422 to RS232. You can still build your own but you would have to purchase an off-the-shelf converter to integrate with it. In this instance it would probably be easier just to purchase the OEM cable.
Thanks again kolyur.
It seems the RS422 converter is no longer the losing factor.
We are unable to source the 8 pin mini din plug.
That being said, a decision has been made to replace the "outdated" plc with a micrologix or something similar.
Regards
Dave
Anyone got a link for a manual on one of these ? In Particular the ladder instructions and IO etc
7,104
Any of you UK boys got the software and cable for one of these ? I have one with fried outputs that i need the program sucking out of ?
5,686
Never saw one of these before, but being asked to help with a Matshshita FP1 model C72. PLC has a fault light on and no run light. Cycling power...
3,136
Hi people. Its my first post, and i am starting, asking for some help. I need to know the pins from this plc so i could connect to the...
3,399
Good morning, Spent some time over the weekend looking for a manual for this thing. Anyone have any info or link to manual? I have a spare unit...
1,375
