Rson Member R Join Date Jun 2017 Location Michigan Posts 520 Mar 27, 2020 #1 Anyone know off the top what the maximum cable length should be between a compact logix controller and some point I/O? I have 10 meters in my head for some reason, but I'm trying to look the info up and not having much luck. Thanks!
GaryS Member G Join Date Aug 2003 Location Lancaster Pa. Posts 1,975 Mar 27, 2020 #2 From what I understand if follows the same as any ethernet about 300ft you get more or less depending you system you can use extenders or I have used wireless radio ethernet extenders for really long range or on equipment that is more mobile
Ken Roach Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Seattle, WA Posts 17,480 Mar 27, 2020 #3 POINT i/O has an ordinary Ethernet physical layer, so the nominal distance for CAT5 or CAT5E or CAT6 cable is 100 meters = 328 feet.
