Unable To Connect To GE PLC VersaMax
Adele
Feb 2024
Cyberjaya
The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program.
The HMI connected to it says "Host Communication Error'. I've done the cable continuity test for the cable from HMI to PLC. It was okay. I also have power cycle the HMI.
So, I'm trying to upload the program from the PLC. I'm using the DB9 cable to Moxa converter connecting to my PC. It somehow didn't connect - No light on port 1.
There is a light from port 2 where the HMI is connected to.
I wonder if the cable I use is a wrong cable? The cable should be okay since other engineer use it too.
Hello to all, we have a E-designer E-600 screen that has a RS-422 connection hooked to our Mitsubishi Plc FXCU series and an Rs-232 connection...
2,346
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
136
Hi, I have recently been making some online program changes to a Q00UCPU plc. I have been using a USB to USB-B connector. And have been happily...
744
I admittedly have never set up a Rockwell Thin Client / ThinManager but I need to step in because a vendor is having trouble making the connection...
670
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
670
