Maximum number of masters controlling a single Link 20E AS-i master
zero2x
Sep 2007
Veracruz
Hi guys, I have a cuestion about the Link 20E AS-i master.
I need to know the maximum number of masters controlling a single Link 20E AS-i master. :confused:
I have two S7-300 PLCs in a PROFIBUS network and I want to read/write through the Link20E master from both PLCs, is that possible without read/write problems??
Thanks :nodi:
Hi Zero2X, I might stand corrected on this but I don't believe your two masters can talk to the DP Link20E ASi Module. I think the Link will operate as a profibus slave to only one profibus master and cannot be shared.
I used one before and had it linked as a slave to one master only. I also had to share this info with another Master on the network so I feed the Link20E slave data back to the Master and then shared the data to the other master by using a DP\DP DeCoupler. There could be better ways!
We are in the process of upgrading our PLC5 machines from Devicenet blocks with analog (current) inputs. We are looking at going to IO Link, due...
2,581
Hi PLCs.net! I was curious: How many axis can a B&R APC910 control? Is there a hard limit like certain AB controllers? I'm new to B&R, so would...
374
I have an existing Compact Gaurdlogix PLC with exising PointIO on it (Some safety and some standard). We will be adding a new panel with more...
3,327
Hello Everyone, What is the maximum number of window creation possible wonderware intouch ?
1,409
Hello, I'm working on a Schneider Electric Modicon M580 system which is on a 7-slot backplane with 3 NOC cards used for it's DIO network. I've...
2,381
