Measuring level in a big 15 gallon pot
gusterminator
Feb 2009
Thunder Bay
85
Hi guys. I am looking for some advice on what to use to measure the level in a big pot. What kind of Level transmitter would be the cheapest and best for a home application and what range should it have for around 15 gallons. I would also like to monitor flow. Any ideas on a cheap flow transmitter?
Gus
The range all depends on the diameter of your pot as this will dictate the height of the liquid.
Can the sensor be partially submerged in the liquid or does it have to be non contact?
The pot is a keg and it is for home brewing. it is 16" wide by 23" high.
Thanks for the advice, I will do a search on home brewing and see what I can find.
based on those measurments....would I need a transmitter with a range say from 0" to 50" H2O?
the cheapest ones work with a potmeter and a float
have a look in arduino, it is a simple processor, and all types of sensors are cheap.
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,764
In our water cooling tank, I've installed and successfully wired up 4 float switches & updated the PLC (big thanks to @parky for that). As a...
46
11,564
Hello, I have an application where I need to measure the salt level/volume in a salt saturator. This is a fairly large tank where we load bulk...
21
6,542
Off topic, but I know you guys deal with all sorts. Basically, I have got a tank, that I need to measure level in. I don't really want to put a...
3,651
I'm trying to find a good way to measure the level of liquid in a tank full of solid particles. In comparison, this application is very similar...
25
14,848
