Fred Floggle
- Join Date
- Dec 2004
- Posts
- 173
moisture meters again
Hi Crispen ,
Any process equipment that "tells lies" is worse than useless . I'll bore you with a little tale of a GLT in croatia where the TM55's were untouched for years - maybe you already know that the old series TM's needed a lit more love than the 710's , and are a bit more affected by ambient conditions . This moisture meter was only accurate around 13% , "OK you say , thats a reasonable exit moisture" , but at anything either side of 13% the thing was all over the place , i could get it better by using CALVAL , but the SPAN was about 4 , if you can't achieve reasonable results with a SPAN around 1 , something is wrong . An overhaul , with new lamp and filter wheel motor makes all the difference . Temperature control was a problem on this machine for two reasons , the customer hadn't made any attempt to segregate power from signal cables , with the consequence that temperatures "changed" about 10C when the drives were started . Steam valves were also a pickle with sticky stems . The whole lot was given the treatment , and the machine run up again .
Just like a new one !! SD's during protocol around 0.2% , and packing temp SD less than 2C - the machine would start up with less than a C48 loose packed of waste that was on the dry side and re-run , not bad for an 7500kg/hr dryer .
If your moisture meters and flow control are naff , you won't be able to improve things much , you'll have to sort them out first . Saying that , if you can get your conditioning sorted..........
Hi Crispen ,
