Unregistered
Guest
U
Dear experts in this website. I have a doubt. I encountered a normal mechanical relay(omron MY4N) not functioning when applying the DC24V. I used multi-meter to check it and the DC24V is across that coil but it never turn on the relay. I change a new one and it works.. May I know where could it be the trick?
I last time also encountering DC24V applying to a normal valve and it is not functioning. Change a new one and it works. The suspect faulty valve send back to its own manufacturing company and verify that the valve is 'functioning properly' and they ask me how i connect my circuit. I just know I connect as per normal only. Where could it be the trick again here...
Hope you all can find out the 'tricks' for me. Thank you.
