medar 3005 isolation contactor problems
bakerboy_99ca
Mar 2004
London Ontario
58
hello everyone,
i am trying to build a nut welder from old parts lying around the plant. it has been built and now into the troubleshooting stage.
i have a slc 5/03 with a medar card in slot 1 and a working program from anouther nut welder loaded into the plc. The other nut welder is without an isolation contactor and the new on has one. i am trying to change the code to implement the addition of this feature but am having difficulties doing so. I have followed the medar integrator's guide down to a t but i am still getting the error " isolation contactor not on when needed "
i know this is pretty low on the details but i am just looking for someone with experience with this type of programming to start up a conversation with.
thanks
mark
Well I am few years late answering this, but oh well for future reference,
there should be a Jumper on the firing board, to indicate there is no Iso.cont.
Does anyone know the name of the device that is used to connect a laptop to a medar/wtc welder to do a backup? Part number, model? Thanks!
2,498
I have a machine that is running a SLC 5/03 with medar/wtc welding cards in it. I need to upgrade it to CLX for motion control reasons. It is...
3,567
I have inherited a system that uses a Parker ACR9000 motion controller with the Ethernet PowerLink option that it uses to control five Parker...
228
Can someone please explain to me in simple terms, the best practice with multiple 4/20ma pressure/flow transducers on multiple different 24VDC...
373
I'd like to talk this through a little: Relays are regularly used for PLC outputs, regardless of a need for signal conversion. But what about...
960
