Medar welder
Amy_Fields
Aug 2013
Toronto
30
Does anyone know the name of the device that is used to connect a laptop to a medar/wtc welder to do a backup? Part number, model?
Thanks!
Thanks for the response Geospark, but thats not the one I am looking for. I used to use it at one of the plants I worked at. It had two cables, the one I believe was HHT which connected to the DEP port on the welder and the other was rs232 which connected to the laptop where I would run weld gateway to backup my files.
Thank you
Perhaps you mean the Data Entry Panel - DEP 100S ?
Part No. 937-1009V1
http://www.weldtechcorp.com/controls/brands/medar/dep100.html
Regards,
George
Thanks again Geospark but thats not it, i have that pendant it only allows a connection to the welder. I am looking to purchase the adapter that allows me to connect my laptop and make a backup.
Thanks again for your help
I have a machine that is running a SLC 5/03 with medar/wtc welding cards in it. I need to upgrade it to CLX for motion control reasons. It is...
3,567
hello everyone, i am trying to build a nut welder from old parts lying around the plant. it has been built and now into the troubleshooting...
4,331
Trying to integration Dozens of Lincoln Powerwave S500 welders into our I4.0 network, ultimately into Kepware. Does anyone have a proven solution...
1,771
Hello, In my new company there is a lot of Sonobond welders model MH2026 with CLF2500 controller. Does anybody have any experience with this...
1,728
Has anyone worked with Miyachi laser welder ? I am having some issues when selecting I/O job select option. I can explain more if anyone has...
1,050
