Sonobond Ultrasonic Welder MH2026 + CLF2500
Roju
Jul 2021
Krakow
18
Hello,
In my new company there is a lot of Sonobond welders model MH2026 with CLF2500 controller. Does anybody have any experience with this machine?
Commissioning was done probably by multiple companies but none of them applied any parameter edit from PLC level. All the parameters are set by hand on CLF2500 controller and must be changed for every product which is annoying for operator.
So far it is only controlled by some pins that are safety and start weld signals. But there is a RS232 socket that is empty but I can not find any information about it.
I would be very thankful for any tip or proper documentation (Yes , I already wrote to Sonobond but would be nice to get info from somebody who already worked on it in the field).
Thank You!
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,289
Looking at a sensor wired directly to a PLC analog input (DL450) and trying to identify a make and model. Sensor is working, but if I sign a...
3,753
Dear, I am wondering if there is an ultrasonic type flowmeter (clamp on) for measuring flow in partially filled pipes. The ones that I was...
3,025
Hello all, This is an indirect PLC question. When detecting distance to the wheels (laid flat, rims up), ultrasonic sometimes gives erroneous...
20
11,026
Dear, I need to measure flow on existing pipe 1.6m diameter, and it is not allowed to remove it, so I guess I will go for clamp on ultrasonic...
2,061
