Ultrasonic flowmeter for partially filled pipes
Charbel
Jan 2012
Beirut
307
Dear,
I am wondering if there is an ultrasonic type flowmeter (clamp on) for measuring flow in partially filled pipes.
The ones that I was able to find were only for fully filled pipes. And if we want to add any additional sensor on clamp on ultrasonic flowmeter in order to make it able to measure flow in partially filled pipes.
Thank you,
Your assistance is highly appreciated,
Charbel
The simple answer is no. Most ultrasonic transmitters measure the velocity of the material in the pipe, then assume the pipe is full, and calculates the flow rate.
Almost all flow transmitters use the same technique, the only difference is how the velocity is measured.
There are open weir flow meters, (often seen in waste water plants) that measure the height of water crossing a weir plate. This is the only flow measurement I am aware of the does not require a full pipe.
What about adding a vertical section in the piping? Wouldn’t that always be full?
I had to help a customer add a meter on their discharge into the city sewer system.
Used a +gf+ Signet magmeter on a 6" pipe that had to be full so I had them add 4 elbows and some pipe to add a 12" vertical pipe as a p-trap to keep the pipe being monitored full.
Google
partially filled pipe flow meter
for technology hits that claim to work
Ultrasonics, like most flow meters, measure velocity. To get flow rate you need cross sectional area, which means depth of flow must be known.
There are two possibilities. The cheap one is an inverted siphon - essentially a U section of pipe dropping below the invert of the main sewer so it is always flowing full. This may be difficult to achieve in a large sewer or a small manhole.
The second is an instrument like the Isco in Dan W's search that measures both velocity and depth of flow.
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,289
Dear, I need to measure flow on existing pipe 1.6m diameter, and it is not allowed to remove it, so I guess I will go for clamp on ultrasonic...
2,061
i want to install ultrasonic flow meter at flare lines ( cold and hot)which diameters are 14 and 24 in so i have some questions in this issue...
2,538
dear, i was looking at the ultrasonic flowmeter from E+H, proline prosonic flow 93W, this flowmeter will be used for sewage applications, and...
2,881
Looking at a sensor wired directly to a PLC analog input (DL450) and trying to identify a make and model. Sensor is working, but if I sign a...
3,753
