Ultrasonic Distance to Wheels
I agree with the use of a laser product. I use ultrasonic sensors with good luck, but only on flat surfaces larger than the cone of the sensor (level in liquid tanks). Ultrasonics can be sensitive to reflection, and change in material.
I have used Balluff lasers in the past with good luck. Their website has a good search and filter feature. www.balluff.com. The BOD001W sensor has a range of 200 to 10,000 mm. It has 4-20mA output as well as two NPN/PNP selectable outputs. They have 0-10V available on a different model. This is just one option from one manufacturer.
I suspect you're getting false echoes that bounce around inside the wheel prior to being reflected back to the transducer. I've had that problem with enclosed vessels sometimes when using ultrasonics. Seems that laser would be a better choice, but I understand that it would miss the presence of the wheel were it aimed at a hole in the wheel. Perhaps a capacitive distance sensor would work?
I believe capacitive sensors are only for very short distances.
The wheel rims have holes, which is why laser signal may shoot through it depending on the orientation and give wrong readings.
maybe the holes are affecting the ultrasonic signal as well.
when you say erroneous values, how far out are they? can the bad readings be removed by an algorithm?
As poster before pointed out maybe a software algorithm can do the job.. take x values over y time sort values min to max delete z values in both ends and then use the average of the remaining values..
I worked on stamping presses with coils of steel feeding into them. The steel had to form a loop as the straightener fed at a constant rate (hopefully) and the feeder for the press pulled in the needed amount in one quick pull. The higher the loop got the faster the straightener fed steel. When the loop was at the low limit the straightener stopped.
Other than one off-brand unit (I can't remember the name of) all the ultrasonic sensors to measure the loop, which then controlled the speed of the straightener, were either Waddington or Banner.
If you were near a Waddington sensor and jiggled a keyring the noise would start the straightener moving at a fast speed.
If there was an air leak, or someone with a blow gun, near a Banner sensor that straightener would take off full speed. On that note if an air leak opened during lunch by the time everyone got back the entire coil of steel would have been fed and now a nice pile (that could be 10 to 12 feet tall for thicker steel) would be behind the press, and everybody grab a cutting torch.
For safety I either put BOTH makes together and monitored for a concurrent reading or tied the straightener into the feeder's Feeding signal to the press and if there was no Feeding signal within the past 15 seconds the straightener wouldn't move.
EDIT: For the OP - is anyone around that tire using an air impact, blow gun, another air tool or air chuck? If it is a tire installer then there usually is a ring of air nozzles around the rim opening to blow air into the tire to get it to swell and seat on the rim.
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,289
Looking at a sensor wired directly to a PLC analog input (DL450) and trying to identify a make and model. Sensor is working, but if I sign a...
3,755
Hello, In my new company there is a lot of Sonobond welders model MH2026 with CLF2500 controller. Does anybody have any experience with this...
1,721
Dear, I am wondering if there is an ultrasonic type flowmeter (clamp on) for measuring flow in partially filled pipes. The ones that I was...
3,027
Dear, I need to measure flow on existing pipe 1.6m diameter, and it is not allowed to remove it, so I guess I will go for clamp on ultrasonic...
2,061
