medoc programming help
Jan 2003
Calcutta
18
I am using a Mitsubishi A1s –s1 CPU and a mdeoc v2.3 dos based s/w. In short, the application deals with 20 proximity outputs to the PLC in a sequencing operation. The sequence which decides which proximity outputs are On and which are off is selected by a mechanical arrangement. All these proximities are mounted on a rotary device .In one revolution a particular set of Ops are On and rest are OFF , in the next cycle some other Ops are On and rest all others are OFF. Total there are 5 different combination of Ops being On or Off and at the end of the 5th sequence the machine again goes back to the first sequence. There is a CAM arrangement which tells the PLC the time when it should check for the proximity ( 20 in number )sets to be ON or Off.
I have written a code to check the sequence, basically a series of NO and NC’s , Now if any Ops is missing or an extra which is not included in the sequence comes Up the m/c stops. Fine till now , next I need to display which proximity has caused the stoppage. Since I have used a series connection in the code how do I pick out the faulty one and generate an op from the PLC indicating the faulty proximity ???
Any help would be highly appreciated ….thanking you all in advance.
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
395
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
543
Is it possible to backup the devices (D,M L etc) in MEDOC? I´m going to change the battery and would like to backup before the change. The CPU is...
1,064
Just wondering what the keyboard shortcut to insert a rung in Medoc is?
1,546
Good day everyone, sorry i know this is old but i would like to receive your help with DOS MEDOC SOFTWARE or WIN version if somebody has it...
5,185
