MELSECNET and CC-Link issue
newguy937
Jun 2014
Ohio
I currently am working on a project that involves adding CC-Link to an existing system that uses MELSECNET/H coax network.
I have a small scale mockup on my desk trying to make sure that there are no issues.
The setup on my desk consists of a main rack with a Q03UDECPU and a QJ71BR11 MELSEC module in slot 0.
The remote rack is also on my desk and it consists of a QJ72BR15 in the CPU slot, a QY10 output card in slot 0 and a QJ61BT11N CC-Link card in slot 3. At the other end of the CC-Link cable is a AJ65BTB1-16TE.
I have things to the point that I can force bits on the main plc and can see the output on the QY10 react, so I have at least some parts of MELSEC working correctly.
I can also force bits on the remote rack through a serial connection to the QJ72 and see outputs react on the AJ65 output block, so I have parts of CC-Link working as well.
What I am having trouble with is I can not figure out how to configure it so I can force bits on the Main PLC and see the AJ65 block react.
I am sure there is other information I need to provide, so let me know what you may need to know and I will dig it up.
Thanks in advance for any help.
What software are you using?
GX Works2 has CC-Link diagnostics built in to it. Also in the project tree under parameters, network parameters, cc-link, what are your head device settings? Can you post a screenshot of the network parameter screen?
Dave
I am indeed using GX Works2.
The screen shot is of the CC-Link network parameters that I have set on the QJ72.
Am I correct in assuming that I should not have any definitions for the CC-Link on the Main PLC?
Also when I look at the CC-Link Diagnostics screen while connected to the QJ72 it appears normal.
I am sorry, I am unfamiliar with the QJ71BR11 and QJ72BR15 modules. I am assuming they are communication modules and there is only 1 CPU on board here.
I will have to do some research on the modules before I can help. I won't be able to do that until later this evening but maybe there is someone else here that can help.....
Correct they are communication modules. QJ71 being a master module for MELSECNET and QJ72 taking place of the CPU on a remote rack.
Thank you for any help you may be able to provide.
As a side note I have reached out to Mitsubishi's Technical support and emailed them everything I have going on and have yet to hear back from them. The gentleman that I spoke with was not sure he could help over the phone or email alone.
I believe I have solved my own problems.
So far I have everything working decently well with bit data and word data.
It ended up being a bad setting in the Network Range Assignment area of the MELSECNET Master unit on the Main rack, I was not moving the right bits in the right spots.
That will do it, sorry I wasn't more help. Glad you got things resolved.
Regards,
Dave
As am I.
I have been beating my head on my keyboard for almost two days trying to figure that out.o_O
This is my first experience with MELSECNET and only my second experience with CC-Link so I really got thrown under the bus with this one.
I figured it out though. Now to start adding the rest of the features. :unsure:
Thank you again for your willingness to help. I appreciate it.
Hello all, I have 7 Q series PLCs on a Melsec net/h network, Ladder Programming none of that fancy smancy ST stuff LOL :p. Were running the...
1,407
I have previously used a A1SJ71AP23Q card to bridge MelsecNet 2 to Q PLC. However, our local supplier told me that card is now obsolete. Has...
1,228
Hi guys, Good day! I just visited a plant wherein a Ship Unloader control is required to be rehabilitated. Existing PLC is Mitsubishi A Series...
1,532
Hey, I have some questions about melsecnet-mini. The CPU is A2A and it have some stations in a melsecnet-mini network. The master is a AJ71PT32-S3...
1,847
HI Anyone can explain how the melsecnet can monitor the other station IO, & trigger an out output eg. Network work 1 Station 1 CPU02H QJ71BR11...
2,429
