Memory Function on TwidoSoft
Firstly, if possible I would reconsider the PLC platform you are learning on, the twidosoft platform is 'very old hat' besides the fact that it is virtually obsolete as Telemecanique were aquired by Shneider and subsequently are replacing Telemecaniques PLC with thier own.
But to answer your question (which by the way is very vague to say the least) the 'M' function is an internal flag or memory ie as your example M0.0 represents memory word 0 bit 0, to adress the whole memory word as an integer you would use the prefix MW ie MW10, and to address a floating point you would prefix MF ie MF50, however be wary that the words and bits can overlap, ie if you use M1.14 memory word 1 bit 14 then use and write to MW1, you will over write and action M1.14. This is a very brief look at the "memory function" and can be and is very much more involved than this.
Steve
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
542
Hi, does it's a function that can remember my intouch memory after I stop runtime? Here the example: When I start Runtime, it will start counting...
3,219
Hi all, I am trying to add a function block to a PLC program written for an Omron CJ1M PLC. However, CX Programmer has thrown a compile error...
5,355
Question for the Siemens experts. In an S7 safety function block, I'm adding two safety function blocks for emergency stops (F_ESTOP1, FB215)...
4,946
Hi, I am still confused when to use just simple memory tags or put it in a data block. The same, when to put your ladder logic in a function or a...
3,280
