Intouch Memory function
Jerry321
Dec 2017
Kuala Lumpur
Hi, does it's a function that can remember my intouch memory after I stop runtime?
Here the example:
When I start Runtime, it will start counting a number 1...2...3...4, and I stop the runtime when it counting 9. After I start runtime again, and the number will continue counting from 9.
Does it possible keep saving my number even I closed my pc?
Thanks for replying, I had try selected the Retentive Value in my integer number.But it will reset the number after restart pc.
Is there are any method that can store my memory even I restarted my pc?
Thank you.
Hello I have an issue with a new PC that has Wonderware & NAD setup. This PC is the NAD master and has the PLC drivers installed. There is one...
932
InTouch : "your system may be running low on memory" and "WWHEAP" errors Hi, I'm trying to run a managed application on a Windows 10...
11,627
So a customer gave me a list of tags they want to import into Historian. The list was derived from an InTouch tag DB dump. The original...
3,996
I have seen numerous Out of Memory Errors across multiple computers and projects that I haven't been able to get to the bottom of. I'm wondering...
3,580
hey guys, i have big problem with CPM2A,my lecturer wants me to set memory on CPM2A from wonderware. I have no clue,🙃 Thanks before
2,594
