Wonderware Historian (InTouch memory tags)
phuz
Jun 2008
Mohnton, PA
1,044
So a customer gave me a list of tags they want to import into Historian. The list was derived from an InTouch tag DB dump. The original integrator used quite a few memory tags which were scripted from I/O tags. I'm guessing Historian has no way of referencing memory tags since it is just using the I/O server and Item Name for all its reference points?
I've done it before, though it was only a few tags and I added them manually (not the import tool).
You'll need add a new I/O server to your IDAS and choose "VIEW" as your I/O server type. For the server location, use the address of the machine running InTouch. Next, add a topic named "Tagname". Use this I/O server and topic when adding tags to the historian.
I have limited experience with Historian, and it's been a long time since I've worked with it at all, but I thought that Historian retrieved tag data from InTouch, rather than from IO Servers, in which case, reading the value of a Memory tag shouldn't be a problem.
Ah hah! Much appreciated! (y)
Hi, we seem to have lost our Wonderware InTouch 9.5 Historian installation CD. Does anyone know how to go about obtaining a replacement CD, or...
2,970
I'm using Intouch wonderware in a really simple application. We need to monitore some variables that are given by a Flow Computer OMNI. I use...
5,595
I have installed a Wonderware Historian 9 + IS3 + InTouch10, 5000 tag system. It connects to 2 DCS OPC Servers and 1 RSLinx Gateway using...
6,770
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
179
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,562
