InTouch NAD & System Memory Issue
Ones_Zeros
Feb 2014
at work
367
Hello
I have an issue with a new PC that has Wonderware & NAD setup.
This PC is the NAD master and has the PLC drivers installed.
There is one client mapped to this PC and it works fine.
The specs are
- Windows 10 Enterprise
- 16 gb of system memory
- InTouch version 2020
- Defender ATP (I’ve added all the wonderware exclusions)
The issue is that Window viewer just randomly closes itself which
causes the client unable to communicate to it. (Note: the site is a un-manned site where the master pc is located)
After troubleshooting this issue for several weeks now, it seems that when alarms
come in on this PC and un-acknowledged the system memory percentage increases in Task Manager. If unacknowledged the memory increases and ultimately causes the PC to start closes apps down.
If I remote in and acknowledge the alarm. The memory % will slowly decrease back to normal.
My question is what would be causing this to happen?
Would this be a Wonderware issue or setting somewhere on InTouch 2020?
Note: the alarmmngr.exe and view.exe memory is within normal range during the memory % spike.
I’ve had AVEVA looking into this issue but they seem to think it’s a Windows 10 Enterprise issue, but I have 100+ PC’s that have Win10Enter that work fine with InTouch version 2020
I appreciate the help and guidance
Hi !!! I'm getting rid of the old IT10.6 that was working on Workstation. I'm using servers with ThinClient (NAD enable). If I run the app, now...
1,393
Hello, I'm having an issue getting NAD to work I attached a screenshot of the error & Configuration on the client NAD computer. Master...
5,537
Hi All, I have a problem with Wonderware Intouch NAD server. When i try to open the Windowviewer via Intouch Application Manager, i get the popup...
5,804
Hi, I am trying to setup a NAD on a wondeware intouch, and I have question. Without the IO server installed and activated to my client station, I...
3,180
Hi, I have an in intouch application which is distributed to two clients using NAD, and application is being used to operate/view Beijer TPOP...
2,300
