.MER runtime program showing errors
ossyben4real
Aug 2017
Lagos
My panelview plus 600 uses Rockwell automation, I powered it one day to discover that the program has crashed, I tried loading other .MER files in the FTVME but it didn't resolved. Can someone with similar experience help me out. This is what is displayed on the panelview.check attachment.
IMG_20170817_075823_027.JPG IMG_20170817_075710_825.JPG IMG_20170817_075758_271.JPG
For whatever reason, the panelview is not communicating with the PLC.
Check your cables etc.
Is their a switch in the network? Is it working.
Can you ping the PLC? Can you ping the Panelview? (Assuming that you have ethernet comms)
This means the panel view can not connect to the PLC.
Did you click OK when the option {Replace the communication} came up. try to download the mer files again to the panel view.
Check in RSlinx if the path is properly assign to the the PLC
I did tried several mer files but still the same.
I'm running the backdoor method to recover a PV runtime file that does not have backwards compatibility but I cannot find the $MER.00 folder in...
2,309
hi Guy, how i can add version 6.10 or 6.00 to my factorytalk view studio, as you can see i can save my Runtime to version 5.10, 7.0,8.0, ...
1,184
FTView - cannot restore .mer "file is not a valid runtime application file." Hello Experts, I was given a .mer file and i cannot restore it...
7,439
Using RSView Studio V3.2 for the first time in 4 years. When trying to create the runtime file, an error occurs "Cannot save database" and the...
6,945
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
