Merging DLG files
springa
Jan 2011
Melbourne
Hi Experts,
I have a small issue I can't find a solution to.
I am trying to copy the log data from a backup of a FTView V11 machine that failed.
The new machine is up and running with no issues except, that I cant seem to get all the old log data to display in FTView. I think I need some way of merging the <datalogmodle>.DLG files. If a use the old DLG file I can see all the old logs but not the new data, and if I use the new DLG the reverse is true.
Is it possible to merge DLG files?
Cheers,
Springa
I would think that you could take the files form the backup and simply copy them to the new machine. I think the default was to create a new log file every day. Copy those daily files into the same folder as the "new" files. I would expect that to work. Don't copy the entire folder. This is assuming the model configuration is identical to the original.
OG
Were you ever able to merge your datalogs? I'm running into the same issue. Looks like all the existing filenames are saved in the DLG file. But I'm not sure if I can open the DLG file with something and edit in the new file names using a hex editor or not, as the first 43 Bytes have different information in them when compared in a hex editor.
Each new filename looks to be preceded with FF FE FF
The end of the files are identical for 0x3D02 Bytes as well.
To start I have been a long-time lurker.. this is my first post. I have used the search function but have not come across something close to what...
1,061
Hey guys, Been a while since I have worked with factory talk view studio, I am also attempting something I have never tried before so I figured I...
4,370
Hey fellas, A few years ago, we upgrade a group of VFDs. We decided to install a ControlLogix plc (call it plc2) to run these drives along side...
1,615
I currently have a project to merge a Network Distributed Application into an Existing Factory Talk Directory. Setup as Follows Factory Talk...
2,246
I have an online file that I need to merge with an offline file, they have different names but everything else is the same. My goal is to get the...
2,072
